Just one larger dish/ orbital location?
Mister B
470
233
El Paso County Texas
I only use the locals from the Welcome Pack. The locals only Pack is not available in Texas. I am getting a signal strength of 20 on a neighboring spot beam which actually locks in but I am doubtful it could ever be reliable. According to the spot beam maps there should be a couple of spot beams off of the eastern arc that transmit over my area.
Would it be possible to get a larger dish such as a 76 cm or even 90 cm to experiment with? If so, what type of LNB and or switch would be needed to feed a two tuner Wally DVR? Beyond that, would I simply run a new "check switch" before pointing the new dish at the other targets? It could be interesting.
I don't know the exact answer but have some info that might help decide if you should try a larger dish. Some DirecTV receives if not all current ones read out signal strength very close to actual Eb/NO like a reading of 85 would be around 8.5dB Eb/No, etc. I forget the exact level where a DirecTV receiver can't decode but I remember its in the 5 to 6dB range. If your Dish receiver works along the same lines then you can approximate the needed size dish to increase signal levels.
Doubling the size of a dish with everything else being the same, like efficiency, LNB gain and noise figure, etc, will give you about 6dB increase in signal level. That plus an existing Eb/NO around 2.0dB might give you 8dB and possibly within a range where the receiver will lock. You wouldn't have much headroom for rain fade but I suspect you would get a picture most of the time.
I see a lock down to around 12, so I think you should "move" your service address to that nearby DMA and see how it goes.
You didn't mention what you have now and what you want to keep connected. In general, the 3-LNB assemblies have an input. So you would get a DishPro solo or dual LNB and connect that up to what you have now.
I think you can do the check switch after you get the 2nd dish hooked up. Or do you propose to use one dish on 61.5? IIRC the 9-day guide isn't present on 61.5.
I have the standard western arc 3 LNB hybrid dish. If I were to try for the neighboring spot beam on 119 I suppose I could connect to the current input and cover the center LNB with foil but to experiment on the eastern arc, I would rather just go with the single dish. I have read many times that a "mixed arc" set up causes difficulties and if only wanting locals there should not a need for the western arc at all.
Is the guide on 61.5 out for 3 days? I could live with that.
Problem Solved. With a bit more research on the spot beam maps, I see that I am getting the signal from Albuquerque with an even stronger reading than my El Paso channels. Albuquerque has many more channels in English and HD.
Reactions: TheKrell
Hopper 3 in loop
4K Joey analog audio output
