Little Saigon/Saigon TV Channels not Working
dukedefile
42
avon, OH
i currently cannot get these channel to work, 11929 v22.000 Saigon and Little Saigon TV, i have a pansat 2700 receiver it gets 90% level but 0% quality, how can i get these channels to work? the the frequency change?
Working here, same freq and SR. 73 Q, S9 and a 30 inch dish. Maybe your's got moved? How are other channels?
well, if it's only "most other channels" I think you need to check the aiming of the dish. Before loosening anything, just push on the dish(not too hard) one way or the other(watching Q meter on a TP that registers), to get a grasp of the direction it's got to be moved. Then check 11929 v22.000 Q.
BTW, is this a fixed dish, or on a motor? If on a motor, maybe just moving it (sat position) a tenth of a degree, or 2, E or W?
all four. one at a time, held long enough to see which way increases Q. then loosen an adjust. May want to mark mount/pole and elevation first. Then you have a reference to return to if something "drops".
No Signal Device in some channels device-Openbox
Is this LNBF related?
