Logitec revue as tv2
Frank7004
715
Indiana
Just curious, couldn't you put the revue on tv2 and use the dish app as tv2 with hd quality?
Of course you would lose dvr integration...
Not sure what you are wanting...
However, you could get HD for TV1 with component cable.
You could get HD for the Logitec Revue via HDMI (TV1 still, though).
However, you would have to watch the same programming on both.
As noted, the Revue only has HDMI inputs/outputs, so you can't get to any form of TV2 directly. Are you really proposing using the DRA application to view the Sling stream from a Sling Adapter on a 722 or the Slingloaded 922?
Yes. Maybe I should have added...sling adapter will also be used. Basically, hook the google box to the tv via hdmi and the use the dish app to watch tv.
So essentially let's say I get a revue and use it on tv2 and sign into a dish sling act. "Tv2" could watch hd.
I guess it could work if your internet is fast enough.
622's are not dead...
VIP222K 1000.4 W unable to find 129
