After a couple of months of enjoying my relocated Shaw dish here in Rhode Island we had the bad storm that hit the US several days ago. The high winds blew my dish downward at the pivot point.  Obviously, I should have had the bolt tighter at that spot. There was no damage to the dish itself or the mast. However, when I raised it back up and tightened the bolt I discovered that I could not reacquire a signal. Both T1 and T2 were reading 0.The elevation is the same as is the skew. I've tried moving the dish left and right with no signal gain with one exception of what might have been a false reading of a signal strength of 34 on T1 (I think) and a lesser number on T2 that bounced up and down. When I went back and moved the dish a fraction the meter went back to 0 for both lines (T1 and T2) and I was unable to get a new number. So with that in mind, I am wondering if my LNB could have been damaged when the dish dropped. I don't have a multimeter here to check anything.  So, with this information in mind...
1) Is there a way for me to determine if there is a fault in the LNB? If so, how can I do so with limited tools?
2) If the LNB is shot I need to get the proper replacement LNB. I have a 75e dish and a new 830 receiver that I purchased after our move to RI. The sticker on the current LNB has been exposed so much that I can no longer read the "model" of the LNB. It has what I would describe as a pair of eyeballs covered in a milky white plastic cover and It has 4 coax connectors. I use two of the connectors for the two lines leading to the receiver. It looks about the same as the XKU triple sat that I have seen available for purchase. But I don't want to get an incorrect item.
3) If I have to get a new LNB are they "plug and play" since I have an activated receiver or do I have to go through my broker who would contact Shaw?
4) Any other suggestions are appreciated.
