Manual for receiver?
GadgetRick
394
Near NYC
Anyone able to track down an actual manual for the HD receiver Voom provides us? It might be helpful since I'm still confused by the darn thing most of the time.
Thanks.
The Rickster
Manual for HD receiver?
Anyone been able to find an actual manual for the HD revceiver we are using with Voom? It would be nice to be able to look up some things. Even with the information provided around here the receiver is very confusing. I would find it very helpful.
The Rickster
Need more...
I have the crappy guide they leave after the install. It's pretty much worthless. I'll check out the installation guide but I'm still hoping for a true manual. I'm wondering if there is one somewhere on the Motorola site. What's the model number of this receiver?
The Rickster
The Rickster
The model number is 550 but it is not on the motorola site the last time I checked. Good luck and if you find something let us know.
Checking...
I'll see if I can dig something up somewhere. If I can, I'll be sure to let everyone know...
The Rickster
I'm still trying to get my Stealth antenna to work. I've noticed there are 3 different inputs on the STB that have the 'antenna' symbol next to it. Which one exactly does the OTA antenna plug into?
If you are looking at the STB from the front then the OTA plugs into the furthest left hand connector. You can tell by looking at the back as the O
TA module has a tab button that allows you to remove the module. This is where the OTA cable plugs in to.
Bill
Tip: Reduce lockups... Keep your STB well ventilated
Look up at Scott's anouncement
