Ok here is some more information about HDCP on Dish Network. This was from a recent document they sent to dealers.
It looks like its coming folks, and if your HDTV only has component inputs some of your HD will be down resed to the "Next best image" possible because of the protected content.
Tech News
• New HDCP Rules – The TV industry is moving toward using HDCP technology next year. HDCP stands for High-bandwidth Digital Copy Protection.
o Types of connections – We can connect a receiver to a display device using an HDMI cable, an HDMI to DVI adapter cable (if the display has a DVI connection on it), or Component cables. Using HDMI or DVI to an HDCP-compliant display is optimal in light of the new HDCP rules.
– To find out whether or not an HD display device is HDCP compliant (Most ViP receivers will have this feature in the near future):
? Connect an HD display device to a ViP-series receiver using a good quality HDMI or DVI cable of an appropriate length.
? Next, open the Receiver’s System Information screen using MENU 6-1-3 – for the next step, you can’t just press the front panel SYS INFO button. Use the Next button at the bottom of the SYS Info screen to move to the “System Info Two” menu.
? Take notice of the “Digital Connection” line. If it says “Yes,” the receiver detects that there is an HDMI or DVI connection from the receiver to the digital display device.
? Then take notice of the “HDCP” line. If it says “No,” this means that the digital display device is not HDCP compliant.
? To view HDCP-protected content in full quality, a customer would need to upgrade to a TV that is HDCP compliant. In the meantime, this customer can use Component cables for a connection.
? In summary, if the HD receiver is connected with HDMI or DVI cables to an HDCP-compliant TV, the customer should be HDCP compliant. If the TV is not HDCP-compliant, use Component cables in the connection for the next best image for protected content.
