Most Of The Guide Is "No Info Available"
slick1ru2
626
21
The South
Like 90% of the Guide is not showing anything known. I did a reboot and forced a download, still like it was before, adding a few shows. What gives?
A reboot doesn't usually force a guide download, do a switch test and that should force the guide to reload.
yep, had the same issue yesterday on my 722k. reboot did not work, but check switch did.
don't know if it was because I had a recording scheduled at the time it d/l's guide info or not.
You will only see the current and next program until the guide fills in. Usually you can force a fill-in by moving the select right hours (arrow) or days (skip). It may require going nearly the 8-day out. This will be only a little faster than a switch check but you may be able to continue recording although the current tuner is used to fetch the guide so you may need to swap in single mode, untried.
-Ken
To get the guide to download you can press 999 Browse in the guide. It will force the guide to download. If it does not work then the current guide it downloaded. This was told to me by a Dish Network Tech Support. It should work on all receivers. I have 2 VIP622's and 2 VIP612's and it work for all of them when I get INFO NOT Available. It is faster than going to the menu and doing a check switch every time
My 722 has had the same problem a few times in the last couple of weeks. Each time had to do a check switch to get it to download manually. Has there been another software download or something causing glitches?
turn off UHF on a 722?
spanish welcome pak
