First time poster, long time reader. Just a quick question. I just upgraded to the 5 LNB and H20 STB, but I am getting pretty weak signal readings from the satellites and transponders.
101 1,2,30,32 - Signal strength 81
110 8,10,12 (I think)- Signal strength 77
119 22 and 26- Signal Strength 77
Now here is the problem, I had 95 with the 3 LNB on 110 and 101 and now it has significantly dipped. It was clear day and everything with these test. I have contacted D* and the installer came out again and said it was as good as it is going to get. He said his meter had mid to upper 80's. Just not on the receiver.
The only thing with this is with Rain Fade, if it does rain the signal will most likely drop so far that I will not get a picture.
Any ideas on this?? Thanks for any and all responses.
