multi room setup
joeybedford
orlando
i have a vip 722 that runs tv1 and tv2 id like to add a 2nd receiver to have tv in one more room i see 2 cables coming from the 2 dishes mounted on my house i get sat 119,110, and 61.5 iknow where the coaxial cable is that goes to the 3rd room is located how can i tie that into the sat feed without disrupting the sat signal do i need a certain switch or what is th easist way to do this thanks
Can you see where the two wires that come from the dish go? They probably go to a ground block somewhere on your house. Find that, and see if one of the wires ends at the ground block. It should. You should be able to just attach the wire going to the third room to that.
Or, the other scenario could be that both wires run to the 722, is that the case? Or is there just 1 wire with a seperator behind the receiver?
"Move" Question
What to do with old receiver
