My Geosat 1200 is confused.
Elkview
332
61
Elkview,West Virginia
I had a 90cm with Stabb 90 connected for most of the year and it would get confused by satellite 125. It would go over and then back to zero. I have reset my box several times over the last several months trying to get to 125. A month or so ago I installed a 120 dish with Stabb 120, and I get the same problem. It went to 125 3 times and returned back to zero. Finally it quit going to 125 and rocked back and forth over twenty times before it quit. Does anyone know what's going on? All other satellites work fine.
For sure sounds like a problem with the 1200. I don't currently have one set up to test here.
Curious does it work fine if you go to 127 or 123?
Works fine anywhere else. I really am confused about it. I have a 90 I can turn to 125 but of course it looses it a lot because of weather.
I'm going to assume you're using USALS so my question is does the 1200 allow seperate motor settings for each satellite and if so is 125 set to USALS or DisEqc? I ran into that on one of my receivers a while back.
Galaxy 19 on a 24 inch dish?
Declination Angle?
