My OTA signal strength is ZERO on all channels
jnardone
376
Hi:
My OTA signal strength dropped to ZERO on all channels tonight. I checked my antenna and it seems to be in the correct position and moving it did not change the signal strength. I have that little amplifier installed in my OTA antenna line so I tried bypassing it but that did not work either. I also pulled out and re-inserted the OTA module and did a factory reset and power cycle. Is my OTA module or box going bad or could it be something else. I am talking about the NY digital channels they didn't all go off the air tonight did they?
Any suggestions appreciated.
Thanks,
Joseph
OTA in NY is up on my box. Connect everything and try to unplug the unit and plug it back. You might have a bad OTA module. Is the satellite still coming? Are you sure that all you connections are tight (even at the antenna)?
I Count Only 27 HD Channels?
NBA All Star Weekend
