My Recordings Group Selection
charlesrshell
SatelliteGuys Crazy
11,381
6,117
O'Fallon, IL
In My Recordings screen when I select Group and then Group by Title, nothing happens. Can anyone explain what this is used for and how do you use it?
That option just groups all the recordings for the same name so when you display My Recordings you'll only see the name of the group. For example, if you have 10 Planet Earth shows if you are not using the group you will then see 10 PE shows listed. If you use the group option then you'll see one listing with PE and then inside the 10 recorded shows.
If you have only one show then it will only list that one show. :)
OK, thanks. We keep our My Recordings pretty caught up is the reason I wasn't seeing the group thing work. I just did a test. Manually recorded the same program three times. Started it, stopped it, started recording again, stopped it, etc. It listed the same show in My Recordings with a 3.
superdish to dish 1000
Local spotbeams ???
