New Construction
redelephants
393
23
Panhandle Florida
I am building a new house and preparing a plan for my structured cabling cabinet(s). I will be installing a television in our great room above the fireplace and will not have any built-ins next to it to conceal the receiver. What is the effective range of the RF remote on the HWS? Also, do you have any suggestions on HDMI baluns or pre-wiring? My plan is to provide 2 quad RG6 and 2 CAT 6 at each room. I'm also planning to bring them into a main structured cabling cabinet (in garage). At that point, I'm going to install 2" conduit to the exterior of the home to bring in the coax from the dish and for future needs. Lastly, I'm going to put an additional cabinet in the pantry for all of my network/video equipment.
I suspect quad shielding is unnecessary and will just be harder and more expensive to work with.
Just curious- are you going to put in wiring for land line telephone service?
Sent from my iPhone using SatelliteGuys App. For now.
Reactions: TheKrell
Thanks for your suggestion. I'm on the fence about it, I currently do not have a POTS line, but use MagicJack so I could benefit from providing jacks, but don't know if the extra cost of cabling is worth it.
Agree Quad 6 is not needed unless you absolutely need it. Great you are putting 2 cat and RG connections at each location. My RF Hopper remote worked quite well thru walls. Cant tell you a distance. Do you really need a fireplace in Florida? Most people up here in Pa. barely use them. A TV mounted high may give you neck aches. Eye level when seated is best. I still use a landline phone. Prices are really cheap for that service nowadays and they are much clearer than cell phones.
I know at one time, at least in some places, all homes had to be built with POTS wiring. I doubt that's still a requirement, unless it's some sort of safety thing.
Are you going to use both Cat 6 in each room? One of them can be used for POTS if need be.
I did all the A/V wiring in our house when we had it built (in 2002). What I wish I would have done...
* Multiple Cat6 cable to each location. Yes, devices can use wifi, but hardwire is going to be faster and more reliable.
* Multiple drops of everything (RG6, Cat6, speaker(?)) on multiple walls of each room. This gives you options if you want to rearrange the room, especially bedrooms.
* Better labeling of cables.
One other thought during construction. Think about eave placement on each corner with front porch and garage coverage of house exterior for security cameras. Most surveillance systems offer a Network Video Recorder with built in POE (power over ethernet). You may not need cameras now, but ten years from now ????????
That's great advice, so many things to consider!
Reactions: navychop and HipKat
Dish 61.5 Bird on Winegard Trav'ler?
