New Customer Stupid Question (Why do the channels repeat)
cnaimo
17
Central Mass
Not sure why this is. it seems like i have duplicate channels in the 9000-9999 range . Called Dish support they didnt have any reason?
thanks
thanks
The 9000 range channels are indeed the HD definition channels for our programming packages. DISH doesn't want customers having to search thousands of channels for their favorite channels so we take that HD channle and "map it down" to the standard channel. TNT is channel 138 which is where customer have been use to watching the channel, so we take the channel from 9420 and send to 138 so your channel has the HD feed. This is called mapping down the channels. We do this for locals as well as they can be at the lower channel numbers and easier for our customers to find.
Reactions: DarrylG
I guess the real question is why is the necessary to begin with...inquiring minds :)
Ross
Sent from my rooted DROIDX (Liberty Gingerbread) using SatelliteGuys
Think of this way using locals. Think of how many cities/areas have channel 3, or 4 etc... To make it easy Dish wants you do know you can go to channel 3 just like you would with an antenna, or usually from your cable company. They can only have one channel 3 on the satellite if they simply put your channel 3 on their system. But, they can put as many channels 3's as they need at higher numbers, so mine might be 5698, yours might be 6433, etc. But then they "Map Down" or simply replicate that channel for you at what looks like channel 3. You are actually picking the higher number. Sort of like Windows and using a shortcut. You know to go to the desktop to open WORD, but WORD isn't where you are clicking it's taking you to a another usually harder place to find to get to WORD.
Reactions: DarrylG
Why does Dish feel they have to do this but Directv doesn't? There are no higher number repeat channels, SD/HD are the same. TBS is 247, TBS HD is also 247, they're next to each other in the guide (if you don't side SD duplicates, which I don't because I can't stand the stretch-o-vision on the Turner HD channels). Locals only appear once, on the actual number. I used to have Dish and just thought it was the way it was and never thought about it until now that Directv doesn't do this. (OR, does Directv do it in a way that customers don't see it. They must with locals for reasons described earlier.)
Dish could "Hide" the extra channels but instead they chose to leave that "option" available to the consumer.. (With the lock and hide feature)
Probably about the only time I see d-tv doing something better then Dish.:eek:
DTV = better with sports. Dish = better with basic "cable" channels. That's not really debatable, it's also why I am now with Directv. I would like NatGeo Wild and a few other channels in HD, but Sunday Ticket and MSG are more important TO ME. Directv's HD picture is very slightly better than Dish Network's but Dish's SD is a bit better. Always a trade-off.
Ok makes sense for locals (honestly I was aware of the need to do this for locals) but why is it necessary for everything else...
Ross
Ross
It's just the way things work with the Dish receivers. Think of it in terms of a computer. You have folders that contain programs, say you want to have two different versions of firefox.exe. Well, it's not possible to place two firefox.exe's in a single folder, therefore you can place one copy of firefox.exe in the folder, then place the different version of firefox.exe in another folder, then create a shortcut named firefox.exe.lnk in the same folder as the first firefox.exe. Well since Windows hides file extensions by default, then both icons would simply appear as "firefox."
Long story short, say you have TBS SD and HD, channel 139, well, there can't be two actual channel 139's so they make the SD actual channel 139 and the HD some 9000 number. Then they place a shortcut called channel 139 to the real location of the HD feed. Now you have two 139's side-by-side, HD and SD.
I'm not sure exactly how DirecTV works, but I have a feeling they just simply hide the duplicate channels.
I honestly don't see what the big deal is really. You can always lock out the duplicates/make a favorites list if they bother you that much. I personally never notice them.
And I prefer having the 9000 range open, so if I record something off SYFY at 9pm, and turn around and record something off of SYFY again at 10pm I can set one recording up on the mapped down channel 122, and then the second recording up on 9432 and get a 1 minute before and 3 minute over run making sure that my full programs on SYFY get record with nothing cut off at the beginning or end.
What I don't understand in all this, is the SD channels are mirrored, but the 4-digit channel number IS hidden. Why don't/can't they do something similar for the HD channels? For example:
[TABLE="align: center"]
[TR="class: FTA"]
[TD]107
4670
[/TD]
[TD]CMDY [107 4670]
CMDY [107 4670]
[/TD]
[TD]Comedy Central
Comedy Central
[/TD]
[TD]MPEG4 SD
MPEG4 SD
[/TD]
[TD]61.5°W
61.5°W
[/TD]
[TD]18
18
[/TD]
[TD]8PSK (2/3)
8PSK (2/3)
[/TD]
[TD]ConUS beam
ConUS beam
[/TD]
[TD][/TD]
[TD]AT120
[/TD]
[TD]Available
Available
[/TD]
[/TR]
[/TABLE]
It's probably just my lack of knowledge of the difference between mirroring and mapdowns.
I think the difference is that mirroring is done on DISH Network's side, and mapdowns are done locally on the receivers.
That's good to know, Halo...the question remains, why don't they mirror the HD channels like they do the SD channels? Or rephrased...why are the high-numbered SD channels hidden but the HD ones aren't?
Anybody using HDMI out into a DVI-D TV?
612 says hard drive failure
