New LNB
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
104,458
31,801
Newington, CT
Here is a new LNB being shown at the Revolution Show...
Its a Reverse Band Legacy, which allows for you to add a dish for the internationals at 95 degrees.
Add a dish for the internationals.
So it would require 2 dishes to get the 4k and internationals .... not just this newest LNB using the dish that goes with it to get it all ?
I bet the 2 on the right are inputs.
Nah, they're undoubtedly outputs ...
The frequency plan for the two new LNB outputs is as I posted awhile ago on another thread. Based on a transponder survey readout from an AIM meter with the latest database update which included the Reverse Band.
The tan colored cells at the bottom of the graphic ("ports 5 and 6") represent the spectrum of the two new coax outputs.
95W will have to be diplexed in on the new 18v line one as shown.
Sent from my SGH-M819N using Tapatalk
And the next question here is ... What type of ext. multiswitch will this RB legacy LNB connect to?
Sent from my LGMS550 using Tapatalk
I would think a swm8/16 switch, no?
Don't think the old analog SWiM switches can handle Reverse Band ...
DIRECTV showed off a digital DSWM-30 ext. multiswitch at a recent Revolution conference I think last year.
So that might be it. ...
Of course the SWM8/SWM16 can handle reverse band. It leaves the LNB at the exact same frequency range as Ka A & B bands, and the internal multiswitch is connected to all six inputs.
Oh, great then;
As it sure would help matters with the seemlessness of installing this LNB if the current installed base of legacy analog SWiM multiswitches could be used by just re-tasking the two flexports.
Though running now six or two more coax lines in addition to an already existing four (or three coax pairs in all) would be a cumbersome and unsightly mess, I see this LNB mainly for MDU single dish solutions.
Now DIRECTV just needs something like this on steroids for the AK-HI dish and they'll be all set I guess. ...
Reactions: Tecnicoloco
Yep it looks like that DSWIM30 will be a part of international integration and 4k reverse band setups. Legacy reverse band LNB w/ DSWIM30 switch and a world direct diplexer. The diplexer will run into port 5 of the switch with both the RB and world direct dish connecting to the diplexer. Super happy to finally see a solution.
You are correct
DSWM 30 for those who havent seen one.
Thanks for posting this photo ...
Humm ...
Guess I need to correct that graphic a bit, as I assumed earlier at the time that the new outlet for the odd RB transponders would naturally use 13v as a continuation of the old 2-level 18v/13v legacy voltage signaling.
But now I see both even and odd RB tps. ports on the DSWM-30 multiswitch are labeled as "18v."
