NFL in 4K HDR YES
RichManitoba
RichManitoba
187
19
Madison, WI
Upconverting is fine if you have a high quality TV set ...
Also, if its going to use HDR that itself will in itself make it well worth the effort to watch.
Nope. It's not as good as the normal Fox local station on DirecTV.
It's blurry with any motion. Looks like a bad recording.
dtv757
dtv757
576
222
757
Looks good on DirecTV
What provider are u using if D* , try going to your local.fox then back to 105
Sent from my SM-N960U using Tapatalk
RichManitoba
RichManitoba
187
19
Madison, WI
I've gone back and forth quite a few times. 105 is actually difficult to watch with any motion. My settings are right. I've watched golf and college football on the 4K channels....they've been great.
rad
rad
10,669
4,363
Dripping Springs, TX
Tune to channel 206 first, than back to 105 to circumvent the frame rate bug.
Reactions: dtv757
Jimbo
Jimbo
65,731
5,242
NW Ohio - Buckeye Country
I have watched off and on tonight ...
I found it hard to watch as it was choppy from time to time ...
I was bouncing between the local Fox and 105.
Some times it looked fine and others not.
I WANT MORE
I WANT MORE
382
71
"Middle of Nowhere"
Despite the broadcast not being true 4k I thought it looked outstanding. No issues whatsoever with the PQ.
I did, however experience a periodic black screen.
This lasted a half second to a second and occurred throughout the broadcast.
I witnessed this on two separate displays.
What I did not experience was the freezing/pixillating that I usually experience on all channels.
Reactions: comp9 and dtv757
rad
rad
10,669
4,363
Again, in case you missed it. There is a bug in the client software, if you tune to a 4K channel from a 1080i channel you might see the frame rate problem. To circumvent it first tune to a 720p channel like 206 or 259 and then tune to 105.
