No Signal
mb7
I've had dish network for 8-9 years no problems. Went to bed last night everything worked fine, this morning no signal at all. I have a dish 500 with 2 receivers, no signal on either receiver. I've checked all cables, everything looks good. Tried re-pointing the dish, nothing. I'm getting no switch box detected from both receivers. I'm thinking bad lbn. Does this sound right? Anything else it could be? Thanks.
Depending on your setup, it could be a switch. Check your lines for an external switch, if you have one, run a line from an lnb direct to one of your receivers and see if you get a signal that way. If you don't have a switch, it is probably the lnb.
Question about returning my dish recivers
Installation Questions (16 apartment with single feeds)
