one dish 77/72/61.5
neftv
199
PA USA
Looks like I lost satellite at 72 degrees..
I have a dpp 1k.4
When I check switch port 1 77 good, port 2 good connection no signal, port 3 61.5 good. Port 4 not used.
Using vip622 was working good till the friget weather of a couple weeks ago here in pa. As it is I only getting the two SATs. Thoughts...
Just a belated update to my old problem. I replaced the dp separator and did the rescan and all three satellites are back now. I did not have to troubleshoot the LNBs.
Sent from my ATRIX HD using Tapatalk
I have my other 2 tvs hooked up with an rf modulator and splitters and rg6 cables. I lost the picture to one of the tvs. Checked all connections and had a good picture to the other tvs. There was a barrel connecter about three feet from the bad tv. I replaced it and got an excellent picture. So, you never know what can go bad at any time. Why would a barrel connector go bad?
I seen barrels fail due to moisture getting in and also seen them
get hot causing eventual failure.
Sent from my RM-820_nam_att_100 using Tapatalk
Al Jazeera ratings and cuts
What the **** is wrong with my ViP622 DVR?
