pansat 3500 alignment??
ultrasquare
5
In the Coolsat 4000 Plus review Iceberg implied that if you set the dish at a Sat that was on your latatude that once you programmed the proper Lat/Longitude that the receiver would program the motor to select the Sat belt. Is this true??? Will the Pansat 3500 do the same????? Does the Pansat have any features for aligning the Sats??? Also, do FTAs decode C-band analog or do Ihave to use my standard receiver for that?
once you have your true south zoned in, all the other satellites SHOULD fall into place by using USALS
Now if your elevation is wrong, you might get some but not all. But the 3500 does have USALS
