Philips 30 second skip
SonicRob
271
Does the Philps 70 Hour DVR have the 30 second skip button or do we have to use the advance button i know the Philips DVR has the FF Button any help will be appreciated. :D
Yes. You can reprogram the ADV button on your remote for 30-sec skip with the following procedure:
While watching a previously recorded show, using the remote, press the following keys one after the other ...
Select - Play - Select - 3 - 0 - Select
Thanks that helps me allot i will try that tommorrow when i turn on my Projector i will skip the commercial quickly. :D
I sure will enjoy
Yep i will enjoy allot i will be one happy camper i can't wait no commercials WOW that is good news i will tell you how it went should be simple. :D
DobyMax said:
If you try it and don't like it, how do you turn it off?
Same way you turned in on, it's a toggle:
And when the unit reboots, 30 sec skip comes up off, so you have to redo.
moving and losing waivers
5x8 switch and antenna input questions
