Fortec Purchased Used SG2100 Motor How To Set Latitude with an inclinometer?
milepost72
16
Kentucky
Purchased a used SG2100 motor of of ebay because my old one started having motor issues. The Latitude and Elevation scales on the sides of the mount are worn off!!! Where do I place an inclinometer on the motor to determine I have it set to the correct latitude? The motor itself or the crank arm that the Dish mounts to the motor?
If possible, on the motor housing: the base where the crank arm comes out of.
But it might be difficult, to put an inclinometer on that?
Alternatively, on the crank arm (while it is at zero-position, of course). The arm of a SG2100 usually has a bend of 30 degrees, if dispointer.com is right, so you have to take that angle into account as an extra angle, while setting the motor latitude.
Greetz,
A33
AMIKO Amiko Mini - Goto X function
GEOSATpro Need help setting up USALS with a HH120 motor
