Quad shield RG-56?
milhouse
Mar 31, 2004
21
New Albany, IN
The cable guy came out the other day to hook up a cable modem and said I had old "quad-shield RG-56" cable running that isn't used much anymore. I was hoping to use the existing cable runs for Voom. Will this cable work or will I need new runs?
cameron119
288
LOL! Be sure you get a different technician if you ever need them to return. RG-56 is not 75 ohm coaxial cable...there really is no reason for you to have had it unless you used a ham/CB radio. Perhaps he meant RG59?
cameron119
288
Quad shielding is generally an unnecessary expense. I'd recommend replacing your RG59 with a good brand of RG6 such as Amphenol's Times Fiber or Comm Scope.
milhouse
Mar 31, 2004
21
New Albany, IN
The installer did say it was overkill to use quad shield. I was just hoping to use it so I wouldn't have to pay the Vomm installer to fish the cable.
cameron119
288
I wouldn't recommend using the 59. The installer should replace any that he/she would have to use. If you would rather do the fishing, you can grab a spool of mid-grade RG6 at the Home Depot, Lowes or a similar establishment. I recommend Times Fiber or Comm Scope for permanent installations. In the end, it really won't matter. The two brands I mentioned all have a self-healing compound to protect against corrosion. However this makes them slightly sticky and a very little bit more difficult to work with.
Voom box decoding cable TV & show in channel guide?
Samsung DLP HLN4365W - how to tell what rez ?
