Quality RG-6 purchasing source recommendations
jpmarto
487
141
E. of Seattle
I'm leary of some of the vendors on Amazon or eBay, and I've learned my lesson using non-swept cable with a 1000.2 install for my Hoppers. I'm looking for about 250' of dual RG-6, with ground lead, underground installable, and swept for 3g. Can anyone recommend a good source? Thanks!!
I recommend Monoprice.com
Stay away from cheep generic CATV coax, designed strictly for economy, with a thin aluminum braid and a copper-coated steel center conductor.
You will pay more for good quality.
As per that site its either 1000ft or 100ft. Unless he's planing on rewiring Yankee stadium, 100ft will run out fast
Yes, it's surprising they carry nothing in between.
Thanks for the advice guys. I've tried the Monoprice coax, but what I bought is not rated as swept for 3ghz and the conduit I am using cracked somewhere and is full of water so I need something that can be buried. 100' isn't enough, so looks like I'll be buying a lot of spare cable.
Your conduit may not have cracked if open at both ends and joints are sealed condensation can fill the cold pipe under ground.
I look for solid copper wire. Far more flexible and I am still using the same cables I started with 9 years ago.
Beware of the Sometimes ABSURD shipping costs.
You may see a relatively low retail price then go to the shopping cart. The price for shipping can be as mush as 25% of the retail price for the cable itself..
Lowes sells a 250' reel for around $33. Not sure of the brand of that reel but two major manufacturers of wire in the USA are Southwire and Cerrowire. Romex brand, of course, is made in Mexico.
I always buy mine from Home Deepot ;-) I believe they sell it in 500 ft but it's been a while since I bought it. I ran all my own 3 Ghz swept quad shield for a 2 H/3J system only to have the installer complain about the shielding hurting his fingers.
Home Depot usually has Belden cable. Excellent quality cable, as with Commscope. Those are the only 2 brands I use and never had any issues.
switching from dish to charter tv
Virtual Joey on PS4
