I have had Comcast Extended (? one step above Basic, not digital) service for a number of years. I have one HDTV tuner, one analog PVR, and an analog TV. Comcast has supposedly "upgraded" the San Francisco Peninsula to digital. I have received their digital conversion boxes, but have not hooked them up or activated them. My HDTV shows analog channels from 2 to 33. It also shows a large variety of digital channels with channel numbers that differ from their published ones. I also get Higher Definition for a number of local channels on strange channel numbers.
I don't want to run my PVR through Comcast's converter box. I can use its programming capability to record programs that come through on the analog channels. I do want to use Comcast's box on the analog TV to get the other channels. I don't know about using the box on the HDTV.
1) Is Comcast expected to "drop the other shoe" and cut off the remaining analog signals?
2) I have not activated the Comcast boxes. If I do activate a box and connect it to my analog TV, will Comcast do something to my feed that prevents my PVR from seeing the analog channels or prevents my HDTV from seeing all the channels that it currently sees? An other way of putting this is do all of the receivers need to go through the Comcast boxes once I activate?
3) My HDTV shows a noticably poorer image on 720 and 1080i HD than it does for Blu-ray DVDs. People often look like they are using gobs of pancake makeup (in Photoshop I would liken this to edge sharpening with surface blur). Is this a characteristic of the program source or is Comcast playing games to reduce the bandwidth of its "HD" channels?
I am a new member and to do not recognize many of the abbreviations that the cognoscenti use here. Please be gentle.
Thanks,
Joe
Thanks,
Joe
