R15 Receiver an IR/RF Remote
ggentry
I have an R-15 receiver and for some time have been using both an RF and IR remote (different rooms). I was messing around with the menus a couple of days ago and now either one or the other remotes work. I can't seem to get both IR and RF remotes to work together. Anyone have an idea how I can get back the ability to use both IR and RF remotes together?
Thanks,
Gordon
As far as I know it is 1 or the other not both modes of operation. Accept that or call tech support and see if they have a different answer.
Thanks,
Gordon
Switch it back to IR mode, then reset the receiver, it will now be in a state like it were never put into RF mode before.
To get it to accept RF signals, just attach the RF antenna and do the following on the RF remote:
1. dtv
2. press and hold MUTE & SELECT for two blinks
3. enter 9 6 1
4. press CH UP
5. enter the last 6 digits of the receiver ID #, found on a sticker in the access card compartment
6. press SELECT
If you want to keep controlling the receiver via both IR & RF, NEVER turn on the RF through the menu.
LNB Test Failed
Availability of Non-local RSN's???
