RAI Channel (61.5 & 121)
311Man
115
If you are receiving channels that are available on both 61.5 and 121 will you see them if you moved dish from 61.5 to 121? Presently have RAI A la Carte pointing to 61.5 with single LNB dish. Would consider upgrade to Panorama Package if moving dish to 121 would work. Also, does anyone know if there is any signal strength differences between 61.5 and 121.
121 is a different frequency band and polarization (and probably power level) from the other Dish satellites. The only Dish equipment you could usefully move to 121 is the 105 LNB of a Superdish 105, I think.
you cant use a Dish300 for 121 as Jim S noted its a different frequency
You would need a Superdish which would replace it. But for fun if you had both 61.5 & 121, the 121 dish would get the signal.
121 is a lower powered satellite so the signal is less (need at least a 30" dish)
Need Info on Install
Letter to charley
