Realigning Dish 1000+ for 118 Only, help!
CCTX
82
United States
I am in the Corpus Christi, TX area. I have what I assume to be Dish 1000+, after looking at the pics, with four sat 110, 118, 119, 129 since I am getting international programming as well.
I looked at the Excel sheet for signal thresholds and everything looks around the average. I have been having issues with "some" transponders on 118; believe it or not during the heat (mid of day time). The signal on these transponders can be as low as 10 to 21. Other 118 transponders are around 40's.
I looked at the correct skew/elevation for my area and the antenna seems to be fine in that sense.
Is there a way to realign for better 118 without messing up the other sats? What is the best way to do so? I do not have a meter but I can have my wife read the signal strength values inside the house for me.
118 is the weakest to begin with and it doesn't take much to get it out of alignment
if you wan t to check it yourself, just gently push/pull the dish in differnt directions WITHOUT loosening any bolts and see if there is any change on the signal strength screen
try transponders 1, 7 or 11 - they should all usually be over 50
These transponders are actually used and they cause some "signal is lost" errors.
1, 7, 11 are all at 45 strength.
I am not sure if this is the best you can get these transponders for my location.
Hopper Install Issues!
Abundance of no info available
