Rv Tri Pod Help
TUNAMIKE
HELLO ALL I AM JUST A DAY OLD NEWBEE SO BEAR WITH ME. I AM TRYING TO GET A 322 RECEIVER WORKING FROM A DISH PRO 500 DISH WITH DUAL LNB AND 4 CABLES COMING FROM IT I HAVE HOOKED 2 OF THE WIRES DIRECTLY INTO THE BACK OF THE 322 RECVR BUT I CAN NOT GET A SIGNAl IHAVE ALL THE ALIGNMENTS IN ORDER I HAVE A CHEAP SAT FINDER GAUGE THAT I HAVE PINGING OFF THE WALL SIGNAL STRENGTH BUT I CAN NOT AFTER TRYING FOR DAYS AND SLEEPLESS NITES BEEN ABLE TO GET A SIGNAL ON THE TV STRENGHT METER ONE TIME I HAD A GOOD SIGNAL BUT AFTER LOCKING ON IT LOST IT IN THE ACQUIRING PROCESS. DO I NEED SOME SORT OF SWITCH SPLITTER ETC OR AM I JUST TO DUMB TO DO THIS. I HAVE SET UP MANY OLD SAT DISHES YEARS AGO BUT THIS NEW GADGET HAS GOT THE BEST OF ME. ALSO I HAVE SWITCHED THE 4 WIRES MANY TIMES IN THE BACK 2 SAT IN JACKS TO NO AVAIL OHM CHECK IS GOOD ON ALL 4 LINES HELP PLEASE. ALSO I MOVE THIS RECVR FROM MY HOME AND BACK TO RV IT WORKS FINE IN THE HOUSE
Maybe if you spoke in a softer voice, someone would hear you. (translation: NEVER type in all caps. Its only for when you need to emphsie a FEW WORDS like this. YOU DON"T TYPE YOUR WHOLE POST LIKE THIS BECAUSE NO ONE WILL READ IT!) Sorry for everyone else that has to read that! lol
The first you need to do is clarify what you are using for equipment.
a 322 only has 2 inputs from the satellite.
A DISH 500 looks at 2 satellites 110 and 119. Are you trying to aim at both satellites? Are you using LNBs with DP(dish pro) in black on them? Your signal meter will probably recognize any satellite not just DISH Network satellites. Your 322 will only lock onto DISH signals FTA or Directv satellites will affect the signal meter but won't lock on 322.
And absolutely stop yelling(capitals)
New installation: No HD despite having package...
Lost all SD channels from guide
