SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 10/13/2007
digiblur
14,190
4
Louisiana
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 10/13/2007 - 77 changes
Uplink Comparison Range: 10/10/2007 12:04P - 10/10/2007 12:29P -
211 - NOTAX (A) removed from EchoStar8 110W TP 19 ConUS beam
285 - HBO EchoStar8 110W TP 13 ConUS beam changed to MAX-E - EchoStar5 129W TP 27 ConUS beam (NA)
285 - MAX-E [MPEG4 HD] added to EchoStar3 61.5W TP 22 ConUS beam (Not Available)
288 - SHO-E (NA) removed from EchoStar7 119W TP 06 ConUS beam
289 - SHO-W (NA) removed from EchoStar7 119W TP 08 ConUS beam
290 - HBO-E EchoStar7 119W TP 02 ConUS beam changed to MAX-E - EchoStar7 119W TP 17 ConUS beam (NA)
291 - HBO2E EchoStar7 119W TP 06 ConUS beam changed to MAX-W - EchoStar7 119W TP 17 ConUS beam (NA)
292 - HBOSG EchoStar7 119W TP 06 ConUS beam changed to MOMAX - EchoStar7 119W TP 17 ConUS beam (NA)
293 - HBO-W EchoStar7 119W TP 19 ConUS beam changed to ACMAX - EchoStar8 110W TP 11 ConUS beam (NA)
294 - HBO2W EchoStar7 119W TP 13 ConUS beam changed to 5-MAX - EchoStar8 110W TP 11 ConUS beam (NA)
295 - HBOFM (NA) removed from EchoStar7 119W TP 08 ConUS beam
296 - HBOCY (NA) removed from EchoStar8 110W TP 11 ConUS beam
297 - HBOLT (NA) removed from EchoStar8 110W TP 21 ConUS beam
389 - NHLHD (NA) removed from EchoStar3 61.5W TP 30 ConUS beam
390 - NHLHD (NA) removed from EchoStar5 129W TP 08 ConUS beam
391 - NHLHD (NA) removed from EchoStar5 129W TP 08 ConUS beam
392 - NHLHD (NA) removed from EchoStar5 129W TP 08 ConUS beam
393 - NHLHD (NA) removed from EchoStar5 129W TP 08 ConUS beam
394 - NBAHD (NA) removed from EchoStar3 61.5W TP 30 ConUS beam
395 - NBAHD (NA) removed from EchoStar3 61.5W TP 30 ConUS beam
396 - NBAHD (NA) removed from EchoStar3 61.5W TP 30 ConUS beam
397 - NBAHD (NA) removed from EchoStar5 129W TP 08 ConUS beam
398 - NBAHD (NA) removed from EchoStar5 129W TP 08 ConUS beam
399 - NBAHD (NA) removed from EchoStar5 129W TP 08 ConUS beam
695 - CCEF renamed to CCTVE (A)
724 - GKINO moved from EchoStar9 121W TP 22 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
725 - DWTV moved from EchoStar9 121W TP 18 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
726 - PRSBN moved from EchoStar9 121W TP 22 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
731 - TV5 (A) removed from EchoStar9 121W TP 13 ConUS beam
842 - TVCHL (A) removed from EchoStar8 110W TP 19 ConUS beam
884 - CCEF renamed to CCTVE (A)
5550 - MTS01 [MPEG2 SD] added to EchoStar1 148W TP 13 ConUS beam (Not Available)
5551 - MTS02 [MPEG2 SD] added to EchoStar1 148W TP 13 ConUS beam (Not Available)
5552 - MTS03 [MPEG2 SD] added to EchoStar1 148W TP 13 ConUS beam (Not Available)
5553 - MTS04 [MPEG2 SD] added to EchoStar1 148W TP 13 ConUS beam (Not Available)
5554 - MTS05 [MPEG2 SD] added to EchoStar1 148W TP 13 ConUS beam (Not Available)
5555 - MTS06 [MPEG2 SD] added to EchoStar1 148W TP 13 ConUS beam (Not Available)
5556 - MTS07 [MPEG2 SD] added to EchoStar1 148W TP 13 ConUS beam (Not Available)
5557 - MTS08 [MPEG2 SD] added to EchoStar1 148W TP 13 ConUS beam (Not Available)
5558 - MTS09 [MPEG2 SD] added to EchoStar1 148W TP 13 ConUS beam (Not Available)
5559 - MTS10 [MPEG2 SD] added to EchoStar1 148W TP 13 ConUS beam (Not Available)
5560 - MTS11 [MPEG2 SD] added to EchoStar1 148W TP 13 ConUS beam (Not Available)
5561 - MTS12 [MPEG2 SD] added to EchoStar1 148W TP 13 ConUS beam (Not Available)
5718 - GKINO [MPEG2 SD] added to EchoStar9 121W TP 22 ConUS beam (Available)
5719 - DWTV [MPEG2 SD] added to EchoStar9 121W TP 18 ConUS beam (Available)
5720 - PRSBN [MPEG2 SD] added to EchoStar9 121W TP 22 ConUS beam (Available)
7648 - KFBI [MPEG2 SD] - EchoStar2 148W TP 18 ConUS beam changed to Available
9561 - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9561 - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9562 - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9562 - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9563 - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9563 - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9564 - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9564 - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9565 - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9565 - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9566 - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9566 - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9567 - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9567 - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9568 - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9568 - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9569 - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9569 - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9570 - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9570 - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9571 - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9571 - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9572 - NBAHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9572 - NBAHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9646 - ATT [MPEG4 HD] - EchoStar5 129W TP 06 ConUS beam changed to Available
9791 - MIG1 renamed to MOVE1 (NA)
9792 - MIG2 renamed to MOVE2 (NA)
19068 - TCHEF (NA) removed from EchoStar7 119W TP 02 ConUS beam
Transponder Changes:
EchoStar1 148W TP 13 ConUS beam QPSK added to tables
Channels in the system: 4472
(A) = Available to subscribers
(NA) = Not Available
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 10/13/2007 - 7 changes
Uplink Comparison Range: 10/10/2007 02:41P - 10/10/2007 08:25P -
285 - MAX-E [MPEG4 HD] - EchoStar5 129W TP 27 ConUS beam changed to Available
285 - MAX-E [MPEG4 HD] - EchoStar3 61.5W TP 22 ConUS beam changed to Available
290 - MAX-E [MPEG2 SD] - EchoStar7 119W TP 17 ConUS beam changed to Available
291 - MAX-W [MPEG2 SD] - EchoStar7 119W TP 17 ConUS beam changed to Available
292 - MOMAX [MPEG2 SD] - EchoStar7 119W TP 17 ConUS beam changed to Available
293 - ACMAX [MPEG2 SD] - EchoStar8 110W TP 11 ConUS beam changed to Available
294 - 5-MAX [MPEG2 SD] - EchoStar8 110W TP 11 ConUS beam changed to Available
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 10/13/2007 - 8 changes
Uplink Comparison Range: 10/10/2007 08:25P - 10/11/2007 09:46A -
8320 - KNXV moved from EchoStar7 119W TP 05 Arizona beam to EchoStar10 110W TP 20 Spotbeam 35(AZ) (A)
8321 - KPHO moved from EchoStar7 119W TP 05 Arizona beam to EchoStar10 110W TP 20 Spotbeam 35(AZ) (A)
8322 - KPNX moved from EchoStar7 119W TP 05 Arizona beam to EchoStar10 110W TP 20 Spotbeam 35(AZ) (A)
8323 - KSAZ moved from EchoStar7 119W TP 05 Arizona beam to EchoStar10 110W TP 20 Spotbeam 35(AZ) (A)
8327 - KTVK moved from EchoStar7 119W TP 05 Arizona beam to EchoStar10 110W TP 20 Spotbeam 35(AZ) (A)
8328 - KTVW moved from EchoStar7 119W TP 05 Arizona beam to EchoStar10 110W TP 20 Spotbeam 35(AZ) (A)
8329 - KTAZ moved from EchoStar7 119W TP 05 Arizona beam to EchoStar10 110W TP 20 Spotbeam 35(AZ) (A)
8330 - KFPH moved from EchoStar7 119W TP 05 Arizona beam to EchoStar10 110W TP 20 Spotbeam 35(AZ) (A)
How much Hockey can I get without CI?
211 recording to pocketdish
