SD Out on 622
bkushner
681
Audubon, NJ
I want to send a recording from my 622 to a Tivo device. With my old 921 I would simply hook up RCA cables and pick SD mode. How is this done with the 622?
Brian
The 622 is different than the 921. You can still us the composite outputs (RCA), question would be which set due to which mode you would be using. If in single mode, won't really matter, but if you are going to start using dual mode, it would have to be tv2 outputs. Setup would have to include makeing sure the channel you want is tuned on the correct tuner. You will probably have to play with it to get used to it. Also be wary of the 'inactivity standby' located under the 'preferences' menu.
