Skew problem (1 Viewer)
bigrick7
Thread Starter
Jul 31, 2011
I go to dishpointer website and skew for my location is 25.6.
There is no 25.6 on the 3 LNB directv dish skew on goes to about 35.
When I use the dishpointer app it's say my skew is 66. Is there an
Adjustment I must do like add 11 to get proper skew? Am in Puerto Rico.
Zip is 00719 if that helps. TIA
AlanSH
DishPointer.COM Admin
355
Did you select the 3 LNB dish on the dishpointer website? Also hover with the mouse over the arrows on the website which gives you an explanation how the skew works.
bigrick7
Thread Starter
Jul 31, 2011
Yes I selected 3 LNB on the website hovered over area
The skew is still 25.. On the dishpointer ar pro the skew by is 67.
AlanSH
355
The skew on the website is absolute value to which you set the markings on the dish. The markings start at 90 degrees when there is no skew. The app tells you BY how much you to skew. So, if markings start at 90 and you should skew by 67 then the resulting marking would be 23 degrees (90-67=23).
Since the skew markings don't go that far on your DirecTV dish, I would assume that you might not be able to receive DirecTV at all in Puerto Rico but that's just a guess - other members here are probably better informed than me.
Users who are viewing this thread
