Slow Remote Function Try this.
stonecold
3,487
Directv La La Land
Built into the remotes is a id system. the remote sends extra info to the reciver like its model number it battery strength etc Which on some boxes cause it to respond slowly to remote commands.
Follow these steps to disable the extra info it may or maynot help.
Press and hold "Mute."
While still holding down "Mute," press and hold "Select" until green light flashes twice.
Enter 9-6-3 on numeric key pad.
Green light on remote should flash twice.
Press "Chan Down" key.
The End
The End
And to turn the extra stuff back on if it doesn't help in your case ?
stone if you remember correctly my question was about the harmony........no info on that????? (sigh............)
:p
An exceedingly expensive solution that often doesn't improve performance. It does indeed take away from the feature set of the equipment though.
It was a joke, notice the smilies, but with my harmony not one of the functions that are on the D* remote is gone, I have them all.
Forget it. I was able to get it working again.
To reset all the functions of the remote control to the
factory defaults (the original, out-of-the-box settings),
follow these steps:
1. Press and hold the MUTE and SELECT keys at the same
time until the green light flashes twice, then release
both keys.
2. Using the number keys, enter 9-8-1. (The green light
flashes 4 times.)
follow these steps:
both keys.
flashes 4 times.)
Thanks Jimbo. You are awesome.
Transponder location
new here
