Since the 105 and 119 LNB are mounted together, is one port for the 119 signal and the other for 105, or is it like a DP twin LNB were both signals are on one port, but when you put them into a switch, 2 separate signals are read?
If I were to connect a receiver directly to one of the ports on the 119/105 LNB, would the receiver read it as a DP single for 119 single port, then 105 DP single on the other?
Thanks!!!!
Thanks!!!!
