Most must not have gone to the FAQ section to find answers to their questions!
Lots of questions and pages & pages of answers. Yes some could be vaporware, but still looks promising! Check this out and see what is said.
Future Features: I would like to know the timetable for incorporation of support for HD
HD support is planned for mid 2004, it is based on getting upgrades to the hardware to support correct HD output and also the ability to record HD broadcasts
Last update: 2004-02-06 14:27
Future Features: Will you have 720p, 1080i, and 1080p support in the future?
We currently do not support HD, but plan on supporting it by mid 2004. We need to update the hardware to support correct HD formats, and will support 720P and 1080P, probably not an interlaced format such as 1080i.
Future Features: did i understand correctly reading that the Telly is upgradeable to hdtv by swapping out the tuner card?
We will provide an upgrade path for existing Telly users to go to HD. The tuner will change and depending on the HD monitor that you use, you may need an upgrade to the mainboard. The current mainboard has analog RGB component video out of the VGA connector...many HD monitors accept this. But if your HD monitor requires the YPrPb component output, then we need to upgrade the mainboard as well.
Last update: 2004-02-09 12:02
Also we are waiting for a HW manufacturer to finish an HD compression solution for recording HD.
Last update: 2004-02-06 14:34
Current Features: Can you watch a recorded program while recording another?
Yes, you can watch one prerecorded program while recording another.
Last update: 2004-02-06 13:35
The MC1200 is designed to accommodate more storage. From the comfort of your living room, Telly provides a suite of innovative applications to store, manage and access all your digital media while making this same media available to all computer systems on the home network. Note that an IR Adapter is required for digital cable and satellite subscribers.
We cannot record HDTV on the current Telly, but existing customers can upgrade to an HDTV tuner and have the ability to record HDTV without having to buy a new unit.
Last update: 2004-08-12 17:30
We are working on an HD version. The current Telly unit can output HD via RGB output, but many HD monitors/TVs don't have RGB input, only component HD input. The next Telly hardware upgrade will output component HD.
Last update: 2004-08-12 17:24
http://www.interact-tv.com/itvfaq/index.php?sid=10284&aktion=anzeigen
