So I've been banging my head against the wall for awhile trying to figure this out and now before I go ahead and do it, I wanted to ask if you think it will work.  I upgraded from SD to HD a few years ago and the installer came and switched the dish with the Triple LNB dish.  Now I have four cables coming into my basement.  The installer said two were the new HD cables and the other two were SD cables.  I feel that might not be right?  Anyways here we go:
What I'm trying to do:
Have two TV's with a DVR for each.
Both TV's are able to watch something while recording something in the background (two sat in's)
Here's what I am thinking:
Get a 2x4 multiswitch.
I'm assuming the two "HD" lines are the 13v and the 18v.
Run the 13v and 18v into the multiswitch.
Run one of the 18v outputs and one of the 13v outputs to one DVR.
Run the other 18v output and the other 13v output to the other DVR.
Problem solved?
Things I'm confused about:
Shouldn't all four lines coming from the dish be HD and just the Cable box decides whether it displays in HD or not?
Do I need a multiswitch or a SWM?
Do I need to put a B-Band converter on all four post-switch lines right before they go in the DVR? If not where do I put the B-Band converters?
I'm a big fan of MSPaint diagrams so here's what I have and then after that is what I want.
Problem solved?
		 .  But regardless, I AM missing channels.  When I reset my HR22 with dual tuners I get the local HD channels but not the national HD channels like DiscoveryHD, CNNHD, etc.  It says Searching for Satellite 2 or something of the sort Error 711.  Then when I unplug one of the tuners and reset it to look for only one tuner, it works just fine!  I have put BBC's on both tuners and switched them and it didn't help so it's not them....
