Unique IR codes for 2 Tivos
jcarr
23
I am about ready to purchase a HR10-250 HD Tivo and a SD Direct-TV Tivo. I want to install them in the equipment rack in my theater where they can feed the theater and the RF distribution network to the rest of the house. Will one remote control both Tivos, or can they be uniquely programmed to control just one unit? The desire is to have a unique remote just control just one tivo, without messing up the second unit.
If you have the HNS Tivo, it is on pg. 115 of the owners manual, or in the Table of Contents, under "Programming the Remote Control"
Path on On-screen Menu: DIRECTV Central//Messages and Setup//Recorder and Phone Setup//Remote Control Programming//Set Remote Address
Follow the directions from there and you should be good. This is just going off of memory, so I'm not 100% sure if this is correct or not, but I hope this helps.
I just checked this, and actually, the correct on-screen path is:
DIRECTV Central//System Information//Set Remote Address
Help with rural co-op local provider on D*
Dolby 5.1 which reciever would I need??
