What would be needed to use my directv slimline with orby I would find it hard to believe it would not be possible because orbys dish looks almost identical
Actually what looks to be almost identical to the Orby dish, even right down to the 11.7-12.2 GHz linear LNBF.What would be needed to use my directv slimline with orby I would find it hard to believe it would not be possible because orbys dish looks almost identical
Yes from what I read I figured I would have to replace lnb any good suggestions on lnb and signal meter to know if I have any signal I have already set the dish to the 230 azimuth and 39 elevation that's suppose to be right for my areaMore than the dish- LNBs are not interchangeable. Some would work, some won't.
If someone called for support no signal or the like they would want to be able to ask customer what is signal strength.Wouldn't have figured the receiver would have a signal meter since its meant to be installed by professional
![20190328_134340[1].jpg 20190328_134340[1].jpg](https://cdn.satelliteguys.us/xen/data/attachments/118/118844-75f854f8ecf5c808e240d016ab2cb474.jpg?hash=dfhU-Oz1yA)
Did you get this to work? I am considering doing the same thingWouldn't have figured the receiver would have a signal meter since its meant to be installed by professional
Sometimes signal meters are used by CSR's to troubleshoot issues at end users homes.Wouldn't have figured the receiver would have a signal meter since its meant to be installed by professional
Sorry to leave you hanging but i lost interest in this for a while but now i have talked my mom into getting orby im gonna see if i can make it happen also did you try it and did you get yours going?Did you get this to work? I am considering doing the same thing
Congrats! I modded an old slimline for Orby as well a few months back. I had signal within 10 minutes of mounting. Glad I kept the dish around after canceling DirecTV years ago!Ok so I was sucessful in finding signal with the slimline dish and linear lnb made to fit the old 18 inch round directv dish which slipped right in had signal within 5 minutes so yes it can be done takes a little math to get skew right since its setup different from orby dish but yeah it can be done.
I measured where the original lnbf was and used a standard FTA lnbf with a universal mount. Dish is at zero skew, lnbf is skewed. It is mounted on top of the pole for my motorized ku dish. I rushed putting this up during really cold weather,Just wondering how you went about it i used a linear lnb that looked identical to the original directv lnbs and skewed the dish itself did you skew the dish or zero the dish and skew the lnb.
which bothers my hands horribly, so it likely can be dialed in a little better but so far it has worked great.
