Using two UHF remotes w/622
wgeorge
24
Hawaii
How might I program the addresses so that I can use two UHF remotes for a single 622?
The setup procedure using the "record" button in "system info" changes to that particular remote.
Not sure what you want to do. Do you want to use 2 uhf remotes both for TV2 or do you want a 1 uhf remote for TV1 and 1 uhf remote for TV2. If you want 1 uhf remote for tv1 and 1 for tv2 you need a uhf remote with a green tab with it labled tv1 in black. If you only need 2 uhf remotes for tv2 you just need to go to the system info screen and find the address for tv2 and program the second remote for that same address.
Single Cable to Dual Tuner and Single tuner
722 511 software Fast Forward erratic
