Vertical Lines
occammd
397
I am seeing a dashed vertical line in the pillar on the right when I pillarbox SD material @ 1080i or 720p from the rcvr. I know it isn't the cables 'cause it is on component and DVI. I am new to VOOM, was this present in the old firmware, or is it a new "feature"?
Thanks,
Ray
The vertical lines are signal interference..I was told that these new tvs are sensative to signals.. try moving your cables and moving the tv away from the voom box or other electrical equip. this should help.. if it doesn't clear up u could try better cables if it gets on ur nerves as it did mine.
How big is OTA antenna ?
FOX News Channel
