viacast quantum msr 1500
djnrg787
SatelliteGuys Guru
129
i have a viacast reciever and a rca 18" dish and i have it pointed to im pretty sure a directtv satellite in the sw sky i have great signal low quality and i just want to get something to work it just says no signal and i have been looking around for the numbers to put in for lnb lo, down link freq symbol rate and so on all in khz and i cant find anything can anyone help? i just want to try to get picture im usually the one telling people how do things bt this is a turn around. thanks and maybe someone has a good system for figuring out this kinda thing for he future or other aimings figuring the numbers with whats given on certain sites
is there any preview channels or anything like that and im not exactly sure what the numbers have to do with those 3 categories on the settings menu
well my zip is 34685 and i dont have a compus yet but i can try to make a good guess with my gps and my sat finder meter
Code:
                          Palm Harbor, FL 34685
           Latitude 28° 5.802'N Longitude 82° 41.784'W
                         Sat Name Sat Lng Az(t) Az(m)   El  Skew
                     Intelsat 901   18.0W 102.6 107.1 13.7 -59.4
                     Intelsat 603   20.0W 103.7 108.2 15.5 -59.0
                            NSS 7   22.0W 104.8 109.4 17.3 -58.5
                     Intelsat 905   24.5W 106.3 110.9 19.5 -57.9
                     Intelsat 907   27.5W 108.1 112.7 22.2 -57.0
                   Hispasat 1C/1D   30.0W 109.7 114.3 24.4 -56.1
                     Intelsat 801   31.5W 110.7 115.3 25.7 -55.6
                     Intelsat 903   34.5W 112.8 117.4 28.4 -54.4
              AMC 12 & Telstar 11   37.5W 115.1 119.7 31.0 -53.0
                          NSS 806   40.5W 117.5 122.0 33.6 -51.5
                        PAS 6B/3R   43.0W 119.6 124.2 35.7 -50.1
                           PAS 1R   45.0W 121.4 125.9 37.4 -48.9
                     Intelsat 705   50.0W 126.3 130.9 41.4 -45.3
                     Intelsat 707   53.0W 129.6 134.1 43.7 -42.9
                     Intelsat 805   55.5W 132.5 137.1 45.6 -40.6
                            PAS 9   58.0W 135.7 140.3 47.4 -38.0
                         Amazonas   61.0W 139.8 144.4 49.4 -34.7
           EchoStar 3 & Rainbow 1   61.5W 140.5 145.1 49.7 -34.1
                 Estrela do Sul 1   63.0W 142.8 147.3 50.7 -32.3
                     Brasilsat B2   65.0W 145.9 150.5 51.8 -29.7
                     Brasilsat B1   70.0W 154.4 159.0 54.3 -22.4
                 Nahuel 1 & AMC 6   72.0W 158.1 162.7 55.1 -19.2
                        DirecTV 5   72.5W 159.1 163.7 55.3 -18.3
                            SBS 6   74.0W 162.0 166.6 55.8 -15.8
                            AMC 5   79.0W 172.2 176.8 56.9  -6.9
                          Nimiq 2   82.0W 178.5 183.1 57.2  -1.3
                            AMC 9   83.0W 180.6 185.2 57.2   0.6
                     Brasilsat B3   84.0W 182.8 187.3 57.2   2.4
                           AMC 16   85.0W 184.9 189.5 57.1   4.3
                            AMC 3   87.0W 189.1 193.7 56.9   8.0
              Intelsat Americas 8   89.0W 193.2 197.8 56.5  11.6
                 Galaxy 11/Nimiq1   91.0W 197.2 201.8 55.9  15.1
                     Brasilsat B4   92.0W 199.2 203.8 55.6  16.8
                        Telstar 6   93.0W 201.1 205.7 55.3  18.5
                        Galaxy 3C   95.0W 204.8 209.4 54.5  21.8
              Intelsat Americas 5   97.0W 208.4 213.0 53.6  24.8
                        Galaxy 4R   99.0W 211.8 216.4 52.6  27.7
                            AMC 4  101.0W 215.1 219.7 51.5  30.5
                            AMC 1  103.0W 218.2 222.7 50.3  33.0
                           AMC 15  105.0W 221.1 225.6 49.0  35.4
                          Anik F1  107.3W 224.2 228.8 47.5  37.9
         DirecTV 6 & EchoStar 6/8  110.0W 227.6 232.2 45.5  40.7
                          Anik F2  111.1W 228.9 233.5 44.7  41.7
                    Solidaridad 2  113.0W 231.1 235.7 43.3  43.4
                         SatMex 5  116.8W 235.2 239.8 40.3  46.4
          EchoStar 7 & DirecTV 7S  119.0W 237.3 241.9 38.5  48.0
  EchoStar 9/Intelsat Americas 13  121.0W 239.2 243.8 36.9  49.3
                       Galaxy 10R  123.0W 241.0 245.5 35.2  50.5
                        Galaxy 12  125.0W 242.6 247.2 33.5  51.6
             Galaxy 13/Horizons 1  127.0W 244.2 248.8 31.8  52.6
 Intelsat Americas 7 & EchoStar 5  129.0W 245.8 250.4 30.0  53.6
                           AMC 11  131.0W 247.2 251.8 28.3  54.4
                        Galaxy 1R  133.0W 248.6 253.2 26.5  55.2
                           AMC 10  135.0W 250.0 254.6 24.7  56.0
                            AMC 7  137.0W 251.3 255.9 23.0  56.7
                            AMC 8  139.0W 252.6 257.1 21.2  57.3
                     EchoStar 1/2  148.0W 257.8 262.4 13.2  59.6
        Satellite Finder is (c) Copyright 2004, P. Lutus
wow thanks looks like i have to do some dish relocation i have it on a fence that only can see south and south west with the house wall north and south to he left of the dish thanks and tommorow ill have to find out about the lnb settings
The DirecTV/Dishnotwork LNB use a L.O. of 11250
Welcome to the forum !
If you have a single LNB DirecTV dish, its probably pointed at 101w, which is useless for FTA.
Repoint your dish to 119w, and you'll get NASA, Dish Network 101 (Dish welcome channel), a religious channel, a couple of slate channels, and a LOT of music on the audio channels.
ok im at 119 and i got signal but no quAlity but im not sure what the downlink freq and the symbol rate and i want to make sure the lnb is 18v and should diseqc be on or off and 0/12v mode on or off
Note the LO is 11250 instead of 10750. If you have an dish network receiver it can be used to get the best signal. No sub needed to use the signal menu.
Good luck.
thanks i have someone with a dish network reciever and im going to try to get ahold of that, so i will try that
Coolsat 4000 Pro 1.3 Firmware
coolsat 4000 pro question
