Viewsonic Remote Control Codes
stormy1206
Hi All,
First post here....
I have a DirecTV Plus DVR and just switched over to a Viewsonic N3000 TV. The code in the DVR for the Remote (11755) does not work. I pulled up the remote control's PDF and found some other codes but they didnt work either (only difference with these codes is that the TV light doesn't blink twice to confirm so it must not recognize these codes).
Anyone have additional codes for this model of TV? It's kind of a pain to have two remotes in the bed. Do I need to clear out the remote first?
Thank you,
Jaison
If the dell code, 11755 doesn't work, then you're out of luck. Newer codes listed for Viewsonic are in the rc32 & rc32rf remotes available from directv.
Significantly Viewed Channel Question
Flat Under Window/Door Coax Cable Adapter
