Vip 222k picture tear/shear on local HD
gtbaum
5
Baltimore
Hi all-
New to the message boards (and the world of HD in general) and hoping for some guidance on a technical issue before I get someone from Dish out at my apartment.
Since I purchased my new TV a week or two ago (Samsung LN46C630), I've noticed my local ABC HD channel gets what I'd call a horizontal picture tear or picture shear midway down the screen. When there is a fast moving scene or scene changes, a thin horizontal line splits the screen in half and the top and bottom halves of the screen become temporarily slightly offset. The image then also becomes choppy. If I switch to the SD broadcast of this same channel, no issues at all.
It's only the ABC HD channel, all others are fine. I've changed the output on the 222k from 1080i to 720p, makes no difference. Any ideas as to what might be causing the problem? Let me know if there are more technical details I can provide (excuse my ignorance if I've left out something obvious).
Thanks for your help!
Yeah, done the hard reset a couple of times, no luck. It's seemingly so isolated, is there any way it would be a weaker signal for that station than others? Not 100% familiar with how satellite signals are distributed...
Hey try going to the menu on your receiver and then press 6-1-1. This will take you to the point dish screen. Select satelitte 129 and set the transponder to 21. The signal strenth should be above 50. What does yours say???
Not going to be anything a tech can fix. Save the $15 bucks, unless you need to purchase componant cables and they happen to cost more. We stock them on the vans. Probably another issue with the hdmi compatibility. To agree with another post it may be the feed from the local affiliate.
Buying a used VIP722 from Craigs List
RIP VIP 622
