I have a Dish 500 for 110 and 119 and a second 500 for 61.5. They are run to a DP34 switch which feeds a VIP622 and two other SD receivers. This morning I received an message on my screen stating there is a switch problem and to run 'Check Switch'. I did this and received the following:
Sat 1 input - 110 - red X, 119 (says Conn) - X, 61.5 OK
Sat 2 input - OK for 110,119 and 61.5
I switched the connections for sat 1 and 2 inputs on the back of the 622 and receive the same results as stated above, ie., no problems on Sat 2 input. This leads me to think I have a problem with the the Sat 1 input on my 622.
I called tech support, reported what I stated above and he seemed to think it is a switch problem and not a 622 problem. Does this sound right?
