Voom Sensar to DB2?
Kentstater72
445
North of Toledo
I am using the antenna that Voom put in (the Batwing). It works fine for all but one station. The towers are all about 15 miles away with a spread of 25 degrees.
I am also using the cm7775 amp.
NBC broadcasts its digital signal weaker than any other station including PBS.
I get NBC fine in cloudy weather but when the skies are clear the picture pixilates a lot.
Will the DB2 be an improvement? Can I use the amp?
for the amount of money you spend on the db-2, you are better off going to the cm4221.
yes it would be better and you can use the amp.
Advice Needed
Antenna help Please
