[VOOM] Vertical Bars on non HDTV OTA channels
J
jprosise1
Guest
This could be a probleme with my TV (Mits 65" rear proj)and not the
Voom STB. My TELEVISION does not allow reformatting (stretching) in
digital mode through the television controls. Obviously, VOOM's
digital STB only carries digital signals. Therefore, non HD OTA
broadcasts have black vertical bars on either side of the picture.
This problem is corrected when an HD show is broadcast. Also, I do
not have a problem stretching the non OTA channels that are not
broadcast in HD through the VOOM STB or if I choose to watch the OTA
chanels through a non digital (SVideo) input. By the way, this only
effects true HD capible stations such as the major networks. The
brodcast for other OTA stations that are digtal but not HD do not
have this issue through the STB.
My question is this: Mitsubishi warns against watching any more
than 15% of total viewing time with the screen not full because of
potential (subtle) screen fade as the TV ages. Does anyone know if
A)there is a way around this and B)is this screen fade really a
significant problem?
------------------------ Yahoo! Groups Sponsor --------------------~-->
Make a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
Now with Pop-Up Blocker. Get it for free!
http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/EyMolB/TM
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
<*> To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
My Phillips shifts pixels at a varying rate to prevent burn in, maybe the Mitsu does too? You can also stretch the image through the STB. You can go to the Options and change your Normal To Wide settings to Stretch instead of Letterbox or whatever they call it.
The STB will stretch all channels (including OTA) except the ones that
broadcast in true HD. Obviously this is not a problem when HD
programming is being aired.
-----Original Message-----
From: Dvlos [mailto:Dvlos.1blrpw@nobody.satelliteguys.us]
Sent: Thursday, August 26, 2004 10:47 AM
To: VOOM@yahoogroups.com
Subject: Re: [VOOM] Vertical Bars on non HDTV OTA channels
Dvlos
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129r9vkm5/M=295196.4901138.6071305.3001176/
D=groups/S=1705036932:HM/EXP=1093621824/A=2128215/R=0/SIG=10se96mf6/*htt
p:/companion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=group
s/S=:HM/A=2128215/rand=558469882>
_____
Yahoo! Groups Links
* To visit your group on the web, go to:
* To unsubscribe from this group, send an email to:
<mailto:VOOM-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
Unfortunately that doesn't help some of us. I have a 53" 4:3 TV. I
currently watch my SD channels in the middle of my screen. If I stretch
them they are stretch to a wide aspect ratio and still don't fill the TV.
The correct solution is to switch to 480p when watching SD channels, but
there is no quick/automatic method to do that. :-(
Chris Green
_____
From: Jerry Prosise [mailto:jprosise@bellsouth.net]
Sent: Thursday, August 26, 2004 11:23 AM
Subject: RE: [VOOM] Vertical Bars on non HDTV OTA channels
broadcast in true HD. Obviously this is not a problem when HD programming
is being aired.
Dvlos
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129cpo57n/M=295196.4901138.6071305.3001176/D=gr
oups/S=1705036932:HM/EXP=1093623750/A=2128215/R=0/SIG=10se96mf6/*http:/compa
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=groups/S=
:HM/A=2128215/rand=186266263>
_____
Yahoo! Groups Links
<http://docs.yahoo.com/info/terms/> Terms of Service.
Try putting the Voom box in "native" mode-maybe your tv will fill the
screen. My 4:3 Hitachi does.
> stretch them they are stretch to a wide aspect ratio and still don't
> fill the TV.  The correct solution is to switch to 480p when watching
> SD channels, but there is no quick/automatic method to do that.  L
> Chris Green
> Stretch
> Dvlos
> ADVERTISEMENT
> <81804_0804_c_300250a.gif>
> <l.gif>
> Yahoo! Groups Links
> • To visit your group on the web, go to:
> • To unsubscribe from this group, send an email to:
> • Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
Yeah, but unfortunately then I can't watch 720 channels since my tv doesn't
support 720p. Where is native in the menu anyway? I haven't been able to
find it since the latest software updates.
Chris
_____
Sent: Thursday, August 26, 2004 11:40 AM
Chris Green
is being aired.
Dvlos
ADVERTISEMENT
<l.gif>
Yahoo! Groups Links
.. To visit your group on the web, go to:
.. To unsubscribe from this group, send an email to:
.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Native will not work for me because my Mitsu does not support 720p
(ESPNhd and others)
TV. The correct solution is to switch to 480p when watching SD
Chris Green
Dvlos
ADVERTISEMENT
<l.gif>
Yahoo! Groups Links
Sounds like its time for a new TV
_____
Sent: Thursday, August 26, 2004 11:50 AM
Native will not work for me because my Mitsu does not support 720p (ESPNhd
and others)
Chris Green
is being aired.
Dvlos
ADVERTISEMENT
<l.gif>
Yahoo! Groups Links
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129boup6s/M=298184.5285298.6392945.3001176/D=gr
oups/S=1705036932:HM/EXP=1093625391/A=2319498/R=0/SIG=11thfntfp/*http://www.
netflix.com/Default?mqso=60185352&partid=5285298> click here
<http://us.adserver.yahoo.com/l?M=298184.5285298.6392945.3001176/D=groups/S=
:HM/A=2319498/rand=212164436>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
I hope that was sarcasm. :-( Breaking out the savings account for a major
television purchase isn't usually something one gets to do frequently.
Chris
_____
Sent: Thursday, August 26, 2004 12:13 PM
_____
and others)
Chris Green
is being aired.
Dvlos
ADVERTISEMENT
<l.gif>
Yahoo! Groups Links
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129t7fhst/M=298184.5285298.6392945.3001176/D=gr
oups/S=1705036932:HM/EXP=1093626912/A=2319498/R=0/SIG=11thfntfp/*http:/www.n
:HM/A=2319498/rand=757681177>
_____
Yahoo! Groups Links
Chris
_____
That's the problem with a Mits, if your local(s) don't support both HD and SD channels, then you have to grin and bear it...
Hopefully all new programming will be HD and eventually the old (as in reruns) can be converted to HD...
[VOOM] Re: Vertical Bars on non HDTV OTA channels
Just a question, why did you go for a 4:3 TV ???
How long ago did you get it ? I dont remember seeing any 4:3 proj. @
CC last time I was there. Still some CRT's but no projections.
for a major
frequently.
> Chris
> _____
> From: Eric [mailto:etoop@h...]
> _____
> From: Jerry Prosise [mailto:jprosise@b...]
(ESPNhd
> and others)
> From: Timothy fouts [mailto:timothyfouts@m...]
the
stretch
the TV.
channels, but
> Chris Green
that
programming
> is being aired.
> From: Dvlos [mailto:Dvlos.1blrpw@n...]
maybe
You
Stretch
> Dvlos
> ADVERTISEMENT
> <l.gif>
> Yahoo! Groups Links
Service.
> ADVERTISEMENT
6/D=gr
/www.n
> _____
> Yahoo! Groups Links
Yahoo! Groups Links
RE: [VOOM] Re: Vertical Bars on non HDTV OTA channels
Its about 4-5 years old now. I bought it used from a friend. A deal I
couldn't pass up. When it was bought, very little content was available in
HD, so 4:3 was ideal. Regardless, with a set that large, even letterboxed
is plenty big. I don't have the money to upgrade it any time soon.
Chris Green
Sent: Thursday, August 26, 2004 12:56 PM
Subject: [VOOM] Re: Vertical Bars on non HDTV OTA channels
for a major
frequently.
> Chris
> _____
> _____
(ESPNhd
> and others)
the
stretch
the TV.
channels, but
> Chris Green
that
programming
> is being aired.
maybe
You
Stretch
> Dvlos
> ADVERTISEMENT
> <l.gif>
> Yahoo! Groups Links
Service.
> ADVERTISEMENT
6/D=gr
/www.n
> _____
> Yahoo! Groups Links
Yahoo! Groups Links
$9.95 domain names from Yahoo!. Register anything.
http://us.click.yahoo.com/J8kdrA/y20IAA/yQLSAA/EyMolB/TM
Yahoo! Groups Links
R
[VOOM] No one answered about NFLHD
ESPN: 720p or 1080i? Wilt, please answer.
