What to do with a 5' mesh fill the holes ?
madmadworld
Official TV Watcher
17,337
7,251
up on the roof in SinCity
this dish is not good for C-band these days.
has anyone tried filling the holes and using one (or similar) for Ku ?
duct tape any ideas ?
yes i do watch Red Green
It should work as a mini-BUD, my 4 foot offset gets the stronger tp's on C-band, I suspect the 5 ft mesh should do at least as well.
I recommend the Geosat Pro C2 lnbf, with a flat scalar ring.
- I agree 100% with Brent
However, since you already show two 10' KTI BUDs, that's probably not a serious idea for ya. :rolleyes:
- you could get a prime-feed Ku LNBF and see what it'll do on Ku.
However, if it's as old as I suspect, I wouldn't bet the farm on much satisfaction.
Not to mention the motor/mount it'd take to swing it around.
If you parked it on the bird with the funny skew, would that be useful?
- given your wealth of more suitable hardware, I'd suggest ya find a local newbie, and indoctrinate him into FTA with it! - :cool:
If you're in South West Michigan, I'm willing to be the C-band Newbie to take that dish !! :)
Get a couple of big rolls of aluminum window screen.
thanks alot 1ADAM12 nice idea
how would you attach it to the dish ?
i guess no one has tried this ......................
going to try with tape ing paper behind it at night for a test when i get time and a new pole up.
might be a month kinda slow moving.
Or go to your local printer or newspaper and ask if they will sell you some used printing plates (sheet aluminum)
Use your existing mesh as a template to cut new, solid panels.
I used Galvanized steel flashing to convert my 7.5 mesh to solid. lowes, home depot have it or the aluminum flashing.
thanks
14karat
Long Hair
now these are very good ideas.
Long Hair
how much did it help ?
boy i am getting excited now !
The odds are 100 to 1 that the size of the holes in the mesh will only have about 2% difference in the performance of the dish. Unless the dish is VERY OLD, the mesh is probably seen as a solid to Ku, and the fact that it's a 5' dish tells me that it probably is NOT an old C-band dish, because back in the old C-band days, people didn't buy 5' dishes. That didn't happen until the G-5 VCII days 1990 + era), and by that time I'd bet that virtually all mesh dishes had Ku compatable mesh.
Even if it isn't Ku compatable mesh, filling the holes is NOT going to help, and yes, back in the late 80's, I tried the fine metal window screen coating idea. It didn't work. The thing is, that if the dish wasn't designed for Ku, it's the shape of the dish that isn't Ku compatable, not the size of the mesh. They used to have rules of thumb about putting a pencil through the hole to see if it was Ku compatable, but even with mesh that big, the losses due to dish shape are greater than losses of signal through the mesh.
Anyway, in my opinion (and I'm sure others won't agree :-) ) , if a dish doesn't work well on Ku, it's not because of the mesh, it's because of the shape.
I'm with BJ on this. My first thought when I opened this thread was "Have you tried it on Ku yet?"
Chances are if it will work at all on Ku, it will work as is, unless of course it is VERY old as BJ said. Do the "pencil test" and at least give it a shot with a Ku feed.
As for automating, I've picked up several prime focus 5 footers (gray Laser/clone, no name on the center plate or LNB cover) that are conventional C band operator assy equipped. The mesh is identical to my 7.5 Laser that works very well on Ku. Is this what you are reffering to? (I cant believe Anole let you slide without reminding you that a picture is worth a thousand words.....lol)
Keeping the signal from "leaking thru" (duct tape???:confused:) is only part of the issue. As I'm sure you know, the signal must be reflected back at the proper angle to the feedpoint to be of any use. C band is very forgiving in that respect compared to Ku but even such actions would yield poor results for C band, much less Ku.
......unless it's a "Mad Scientist" thing in which case by all means proceed and report your findings. :)
Personally, if it's a prime focus I would attach a legacy (polarotor) C/Ku feed assy to it and see what happens.
That is what is on my "to do list" for my 5 footers.........
Long Hair
My mesh was in bad shape, most my ku double in signal. And the c-band when up on my pci card but didn't do much for my DCII 4Dtv.:)
it's my avatar
BIG THANKS
Long Hair
have a chaparral bullseye dual c-band & ku w/servo.
will test before and again when i finsh.
the dish is in good shape. have a extra lightly damaged panel to test the mod on.
thanks B.J. & melgarga for the input.
it is a early 90s dish(it's my avatar) it picked up all the pay stations along the arc back then, was the wife's dish.
this project might be a month or 2 away now.
thanks for reading
UpLink for 83w
Listing For History East on AMC4
