why are the "odds" notably lower than the "evens"
  • Thread starter Thread starter diitto
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
diitto
108
Hi... I was recently told that my 99(c) satellite signals were very low (see below)... OK, I believe that... And I intend to work on trying to adjust my antenna soon. But I also need to know what folks thinks it means that all the odd numbered transponders are approximately 1/2 of the even transponder readings... Could that odd/even signal level disparity be caused by alignment?? If so, how??? If not alignment, what might cause this??? A bad LNB???
1-8 28 62 31 61 27 62 26 58
9-16 23 60 23 54 23 60 n/a n/a
Oh, and one other point in case it matters, I have the four output lines from the dish going into the four appropriate inputs of a Zinwell WB-68 6x8 multiswitch (needed because I needed a fifth input to accommodate my system, 2 dual channel H20's and 1 single channel R15)...
Any help would be much appreciated... thanks much... bob...
Camping with Direct TV
