Why does DISH need a 36" dish??
DIRECTV_Mole
20
Maybe this is a stupid question, but I want to know if anyone can give me a technical reason for the 36-inch size of the SuperDish. Consider that E*'s primary bird is at 119 deg. and the farthest bird away from that is 14 degrees of orbit away, at 105 deg. Now consider that D*s primary bird is at 101 and the farthest bird away from that (not counting those used for LIL and International programming) is at 119, an 18-degree spread. So:
DIRECTV - 18 degrees - 18x20" dish
DISH - 14 degrees - 20x36" dish
Smaller orbital spread...larger dish??
all of D*s satellites are DBS. The 105 and 121 satellites E* use are FSS and require a larger dish because those sat have a lower gain.
Actually
Direct's 95 degree slot for int'l reuired a "Superdish" type configuration. FSS band (also known as KU) is lower powered so you need at least a 30" dish
How many receivers allowed on an account?
Why I Wil Stay With Dishnetwork
