We moved into a new house last fall and Dish moved the service.
As part of the installation the tech swapped Wireless Joey Access Point to a new model. The Hopper is now in a a bedroom separated by a kitchen wall with the joeys being less than 30' from the hopper. The installer concluded that the AP-JOEY wifi signal was inadequate (50%) and used an orphan cable tv connector to add a MOCA-Ethernet bridge and connected the AP. This put the AP no more than 15' from either Joey.
The connection to one or both is randomly dropped. The Joey goes black and then puts up a screen that says to go to the AP and use the button. I just navigate to the network settings page and reset the net (which says it will reset the Hopper-router link but appears to reset the Joey-AP link). It comes back. If I ignore it it will take several minutes and self recover. It usually happens once a day, sometimes more often.
Since proximity didn't change I moved the AP back to be adjacent to the Hopper since where he put the MOCA-Ethernet box was horrible (I wouldn't have let him had he asked) since it was in the middle of some statues. The Joey still has a signal strength of 45-60. It still drops the link but at the same frequency as when it was adjacent.
This never happened with the old AP which we had for over 12 years. And the Joeys were on two levels at least 50' and 4 walls from the AP... Signal strength for them was in the 35-50% range and we never ever lost the AP-Joey link.
I assert that there is some kind of interference that is causing the new AP to lose the link. The area has at least 20 different WIFI networks in range of my internet AP so there is alot of traffic...
An additional thing that happend was an extreme latency in remote control activity. Before this AP the skip forward and backwards had a small, coulpe of milliseconds, latency vs. the remote on the Hopper. With the new AP, remote response is up to several seconds. In fact, I've had it take longer to respond than the skip! I've had it take 45 seconds to do a 30 second forward and it is quite frequent that a 10 second reverse to take more than 10 seconds, and it's typically around 3 seconds... I lay this on the wifi link. The video doesn't stutter but that can be because it buffers internally enough to ride through these.
So two questions:
1. Does anyone else have this same problem?
2. Can I get an old AP back (I asked Dish and they said they couldn't.)
Frankly this is getting annoying enough that I'm for the first time in 30 years, considering dropping dish...
the only reason I have dish is for the DVR...
So two questions:
