Xbox 360 as Uverse IPTV STB (Set Top Box)
mdntblu
213
Corona, CA
Does anyone use their Xbox 360 as a Uverse STB?
How does it work?
Is it possible to get the CD or a copy of it so I can install it and then ask Uverse to add my Xbox as a device?
jypagan
Sep 23, 2007
North Alabama
The way it works, you will be charge a $99 only fee for the adapter required for your Xbox and the Xbox remote is included. Also, you will not pay any monthly fee that you normally get charged for additional STB.
mdntblu
213
Corona, CA
The adapter is simply an HPNA adapter to convert your Xbox from Ethernet to Coax but you only need that if you have Coax ran. I have Cat5 ran all over my house so I don't need that and the remote is the same remote that came with my HD-DVD player which is also useless if you have a Logitech Harmony remote.
After I posted this I did more research and was able to find someone who posted the ISO image of the disc online and then installed it on my Xbox. Then called AT&T and had them activate my Xbox. Then I sent back my receiver to save the $7/month fee.
I'm a happy camper. No need for the $99 kit and $55 truck roll.
sam fisher
38
SF Bay area
How is this working for you? Can you describe the pros and cons of using the Xbox as a STB?
Also, all I need to do is buy the equipment (total cost of ~$36), find the iso, and call AT&T to activate? My Xbox is not modded... also, my install in in 2 weeks, so I could gather the needed stuff before hand. Finally, I have a router right by the Xbox. Will I need a HPNA adapter? It will be coax to the house, if that matters.
Thanks!
am7crew
436
Los Angeles, CA
I dont have a xbox as one of my receivers but the only draw back I would guess would be the noise of the xbox, the fans come on allot because they can run pretty hot.
Need Digital QAM Channel Maps For Charter's System In Fort Worth TX
did not start training yet what should i expect
